Using the android app when i try to view live feed it gives me "Unable to play. please try again" i will still get motion alerts and can view the recordings. nothing has changed recently other than an upgrade to android 6.0
When i log in on a desktop, everything works fine.
any ideas? it just recently started doing this.
Solved! I turned off wifi on my ipad. Turned it on again. Logged into Arlo, and now both camers stream live!
Weird!
I am on IOS but this is a common problem. Be prepared to attempt live stream several times before connecting. IMO this is because of crappy over stressed Arlo servers.
keyboardxbully,
When you are using the app and you get this error, are you on your WiFi connection or are you using 3g/4g? Does it always give you the error message or is it intermittent?
keyboardxbully,
Consider trying other applications/data usage when you are seeing this issue on your phone. If you don't have the issue when you are on a WiFi connection, it could be that the 4g data connection is poor.
the problems started after the latest App update. i have had the system for a year or so now, this has never happened. my data reception is not an issue.thanks though....
update on the situation. i do not know how or why, but for the hell of it i turned on airplane mode on my phone and then turned it back off. everythings been working with no hiccups since.
Are you using the app or a browser? WiFi or cell service? Since it's not being reported here I suspect it's something about your setup or device. If using the app, try reinstalling.
Have you tried restarting the phone and reinstalling the app? I don't recall - when away from home, does it fail on both WiFi as well as cell service?
I am away from home. The cameras have worked great for 3 months, until 3 days ago. Now one works fine in live mode. The other just gives "request timed out" on the pc and "unable to play. Please try again" on the ipad.
Help, please!
Try to restart the base from Settings, My Devices, your base station. There's a Restart button at the bottom. Be aware that while this will restart the base sometimes the cameras don't reconnect. While it doesn't seem likely due to the errors you're getting, it's possible the batteries are dead in the problem camera(s).
Weird!
Did you try any/all of the suggestions above?
Lancegibler,
This could be a signal strength issue. Do you have multiple cameras that are affected or is it specific cameras? What signal strength is shown on the cameras screen for the affected cameras? You could try swapping locations of the affected camera with an unaffected camera to further isolate the issue.
I've been having the same issue of it not being able to play live when on my Arlo app. I turned my airplane mode on and off again as keyboardxbully said, and BOOM, now it works perfectly again. So thanks!
Arlo he Cameras are buffering or unable to play. I have about pulled my hair out. Please someone help me!
Olynhill,
Excessive buffering or error messages when attempting to live stream are generally WiFi related issues. What is the signal strength on the affected cameras? Nearby wireless devices or hard to penetrate objects (thick walls etc) can result in the symptoms you are describing. Consider relocating your cameras to further isolate the issue.
