I managed to get logged out. Then i logged in with wrong email/account. Now i cant log in with the right account.
Tried to remove the app and removed it in icloud, but its inlyft the wrong account it Comedy back to.
5 REPLIES 5
Hi Ostman76,
You can log out of from the Arlo app by going to the app, tap on Settings > Profile > Log out and then log in to the correct account.
I have tried that but when i do, the app crash and om back on the home screen.
Try to uninstall the Arlo app, reboot your iPhone, and reinstall the Arlo app. Also try attempting to go on the app using cellular data and/or WiFi.
Tried it, no luck 😞
Now i made a new account and my wife had to add me. But then i cant do all the settings.
If you're still having problems with your Arlo app and your account, I would suggest to contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
