I am unable to log into view my cameras anymore, just sends me back to screen that says “log back in”
Occasionally an error message will show at the top but it’s intermittent and says
(0) http status code to ‘(null)’ .
Any ideas! It’s driving me mad
I have an Apple 10 phone. Running iOS 13.6. Same issue on WiFi and cellular data
Not to put you on the spot corywagner, but have you researched other brands? I think it's unreasonable of Arlo Support to expect us to power our phones off and on every time we want to access the mobile app. If this issue isn't resolved, I'm seriously considering switching to an alternative.
Yes, I too, spent a lot of money on my Arlo system. But Arlo support has been incredibly unresponsive to the multiple complaints on this issue. If they don't resolve it soon, I'll be shopping around for sure.
Seems a very issue topic - looking at the posts here - and a real security topic not able to login using iPhone App to base station (being remote) . Expansive product ; lousy support ..... all - after a while of silence - hearing that support team is working on this and let you know ; how;what;when...... takes this up seriously and not as a regular issue - we are talking about quality security product informing helping to protect properties .it isn’t ......
Arlo app does NOT work on my iphone 11
Error message - http status code is '(null)'.
Arlo needs to fix this. I have spent hours on the phone with Support and nothing has been fixed. I recently purchased a base and 3 cameras for a gift for my sons home, but returned it due to this!
Same here!
Same problem here!
I too am unable to log into view my cameras anymore, just sends me back to screen that says “log back in”
I have spent a lot of MONEY into this system and now it is looking like I have wasted a lot of money...I have been an ARLO user since inception and have various cameras and devices that are all brick when it comes to working with IPHONE IOS 13.6--It works well with PC devices.
ARLO PLEASE HELP!!!!!!!!!!!!!!!
For the last week I haven't been able to log in to the Arlo App. I have deleted the app, reloaded, restarted my Iphone multiple times and no such luck. I either get an error message that says: (0) http status code to '(null)' or it just spins and then goes back to the "log back in" page. I have also logged out and back in.
Anyone else experiencing the same issues and have a resolution?
Thank you
I was able to get onto arlo support chat and they had me turn off my VPN and i was able to log back in to the ARLO app today. Not sure if an update to use VPN and the app will come out or not.
Hope Arlo will resolve this soon as vpn is used heavily .
Same Issue here
Iphone Xs
IOS 13.6
Error on Wifi Or Cel
Same error as above HTTP or Log Back in and Log Out
works fine on laptop
I'm having the same problem. It's been over a week that I cannot use my iphone to log into the app. When is this problem going to be fixed? I'm paying for a service that I cannot use. Arlo needs to fix this or I'm canceling my service.
Same here. Turn VPN off and it works. Still need to get that fixed
Need Arlo to sort out a longer term solution now
I have an iPhone Xs, iOS 13.6 and it happens on wifi and cellular data. It also didn't recognize my phone, though it is the same phone I set it up with, so I had to add it as a trusted device again. Still doesn't let me log into it from my phone, though I can from my laptop, though it is difficult to do because I still have to authorize the computer login via my phone and half the time that times out too.
