Replaced dead battery in a camera with a recharged battery out of camera that is ac powered and 100% charged. When all came back on line a green tool bar at bottom of screen came up that said “Turning camera on”. Turned all cameras off. Did not clear off. Turned back on, didn’t clear. Removed both batteries and re-inserted and brought back on line. No change. Cameras working fine. Everything functioning as it should. Need help in fixing and removing “Turn on camera “from screen. Thanks
install the battery make sure it resyncs, then reboot the base
Will try rebooting base. Thanks
Removed batteries. Powered down base and reset. Powered back up. Cameras synced, “Turning camera on” still on. Removed devices then added back to account, “Turning camera on” still present. Logged out of account and logged back in. “Turning camera on “ was gone. Not absolutely sure that corrected it, but I’ll take it. All good. Thanks for the help.
