“Acess token is expired”?
  • 5 Replies
  • 28698 Views
Paul_FCCL
Prodigy
Prodigy
Today started getting this while trying to open Android app: “Access token is expired” and can’t access my system. Remember seeing this posted sometime before but can’t track it down. What is it.......and how to get back into my system?
Thanks.
Paul_FCCL
Prodigy
Prodigy
That didn’t do it..........what eventually worked was refreshing “things” within the Stringify app. Problem seems to happen when app hasn’t been used for an extended amount of time.
Thank you.
5 REPLIES 5
Paul_FCCL,
Force close the app and reopen, are you still seeing the same issue?
Paul_FCCL
Prodigy
Prodigy
Thank you.
glavine16
I'm getting the same "access token is expired". What's the fix? Closing out the app doesn't help.
glavine16,
Reboot your mobile device, are you still experiencing the same issue?
Paul_FCCL
Prodigy
Prodigy
If you’re using other apps with Arlo (stringify, ifttdt, etc.) look above for suggested solution.
