Have VMB3000 with 5 cameras. I have another base station (same model) and three more cameras.
Unplugged existing base station. (Won’t setup with both plugged in)
I would like to use both on same network/router. I have searched and there are MANY posts, this is supposedly no problem but can’t find anything specific.
I have three base stations on the same network, so there is no problem on this part.
@Box22 wrote:
Most say just get another account which makes sense but I can only get one app installed.
Well, there is only one app to install. And it can only log into one account at a time.
Still, you can add the three "new" cameras to a different account - either on the phone, or on a PC (browsing to my.arlo.com). Once onboarded you can share them with your main account using friend access.
Im not able to put two stations on the same wifi network. It sounds like if i have another account on a different network somewhere I can “grant access”.
Not sure how to do either.
If i go to existing account where it shows “grant access” the area is grayed out and I can’t input anything. (Assuming I had something).
Let's start here.
- Have you created a second Arlo account?
- Have you connected the base station ethernet to your router? Is so, what is the LED status?
- Have you then tried to add device from the second account? If so, were you using a PC or your phone?
Also, did you try resetting the new base station (using the paper-clip reset) before re-adding it?
If the base was first added to your main account, then you do need to remove it from your old account.
One system has been set up and working for several years.
@Box22 wrote:
Also the only thing I see in the arlo settings to “share” anything is a setting “grant access” but it does not allow me to do anything.
That is the right place to share the cameras. But first you need to onboard the second base to your other account, and add the cameras to it. Then you can share those cameras from the second account.
@Box22 wrote:
I have another account. I could disconnect the old base and put in the new one and get it working with a different account.
You won't see both bases in the same account. You'll only see the base you added. That's not a problem, it's just the way the system works.
After you do this, can you onboard the cameras to the different account?
@Box22 wrote:
but I’m right back to plugging in two bases on same network.
You should be able to simply plug that older base back into the router. The original account will see the original base+cameras, the second account will show the added base and added cameras.
Then share the cameras in the second account with the original account.
