Hello, I recently ( 2months ago) Installed the arlo wireless system with three active cameras. This is to monitor movement of an elderly person in the evening. Sometimes I will get the alert email, but it might take more than a minute to load the live picture. Although it has not been a problem yet, the delay in loading could be critical if there is a fall. It has gone off line once, which required me to drive to the residence to re-boot the system. It is hooked up to a 2.4g modem. I have been able to view movement over 70 miles away, but at times it takes too much time to load the live image.
I would appreciate anyone who may have found a resolve for this problem. I really prefer that I can load real time pictures consistently.
any suggestions or feedback would be greatly appreciated.
Thanks in advance to the community
arloguthrie
Arloguthrie,
When you notice the issue, are you using the mobile app or the web client? Do you see the same behavior on both?
It is when I use my mobile app. I do not usually access my home computer. I did set it up for future use though.
Now, It seems with my basic subscription, that I get motion alerts, however no video is recorded....I usually delete the video after each viewing.
Am I doing something wrong?
I have reset the base station once already, but lately it seems to take over 30 sec. to load the live images. and now no recorded video. Could I possibly have gone over the alotted storeage even though I delete everything?
I am getting confused to say the least. I cannot even find an area that tells me how much storage is used.
Thanks for you help.
There was a temporary limitation displaying thumbnails and videos the Arlo library. This issue has been resolved. Please contact customer support if you have any questions. Thank you!
Arloguthrie,
This could be due to data speeds on your mobile device. Do you notice this more when using 4G/LTE data or do you also see the same behavior when connected to WiFi?
Arloguthrie,
The Arlo base station connects via ethernet, not wireless. Who is your ISP and what are your download and upload speeds?
