I am annoyed to death and can not find any setting to disable sound. I know Arlo (not Q or Pro) has one way sound detection but HOW do I disable it??
Have played with various setting including motion sensitivity and this audio is a mystery so far.
Any one else has this or do I have a defective unit?? I have tried a different Arlo with same results....
HELP!!!
Mode tab, click on your base, edit your modes (probably the Armed mode) and turn off the re ord on sound. Be sure to save.
A little poking around in the app or web interface goes a long ways.
I'm not locating audio adjustment to turn off audio detector. I click on my base, go to armed edit, but i don't see the audio option to turn it off.
Also, can basic Arlo record sound?
No, a regular ARLO camera can NOT do sound.
If the other person has an ARLO camera (not a Pro model ) the only other thing that may be happening is false triggering from IR reflections
No such option available for Arlo !! Ignorance is a bliss 😉
False trigger could be from IR reflections possibly. I see light flashes in fake alert videos. Could a vehicle cause false IR alert?
Thanks for those who provided insights into Arlo. I am annoyed by 90% false alerts and sure others are too.
I have a VERY basic setup - nothing out of ordinary.
Mudit wrote:
I am very curious IF "others" have similar issues or concerns. I have a basic Arlo. Is this issue not applicable for Q or Pro?
Some have said that flashes of light can set off the Arlo.. I haven't seen it.
What I have seen is other Arlo cameras IR illuminators looking like someone turned on light in another area tho.
As to the Q, it uses pixel based motion detection and not PIRs like the Arlos.
While the PRO uses PIRs to sense motion, it is a much improved dual sensor so reacts differently from reglar Arlo.
Any help would be appreciated
