Total Battery failure across multiple cameras
It sounds like for some reason the base went down,,,
when this happens you lose the cameras and they drain at a faster rate than normal trying to resync.
I recommend a UPS on the base unit , esp for remote locations.
This sounds very similar to what is happening to mine. I now have one camera that refuses to sync to my base after a factory reset. I went 4 years without issues, now the entire system is garbage.
Have you used the Contact Support link at the bottom here? Even out of warranty questions will be answered for free.
I had reached out to the teach support. After 3 months and 8 emails, I was being told the same 3 steps over and over. Unplug the base, change batteries, resync the camera. There was nothing done to help looking into the issue. Once I asked why we were just going through the same loop, they responded saying they have tried everything they can. They never asked for firmware versions or camera types.
