Acquired the cameras for use in Panama , I need a time zone , always use GMT -05: 00 Bogota , Lima , Quito , however from the options there and more like GMT -05: 00 New York City, but has a hour apart , could you please help me
prob daylight savings time mix up we use here... use -4 gmt
don't work, GMT-4 (Santiago, Chile) is the only option, but the time is different
Good afternoon Xiegdel,
Can you provide additional details as to what time zone you are located in and the time difference is between your actual time and GMT-4 (Santiago, Chile) so I can investigate this issue further?
I look forward to your update!
Christine
Arlo Team
____
Please click
KUDOS or REPLY if you found this helpful.
My country is Panama. My zone is GMT-5 (Bogota, Lima, Quito), if I use GMT-5 (New York, New York, the time increases by one hour, if I use GMT-4 (Santiago, Chile) the time increases in two hours, if I Google it "time in Chile", shows me, Santiago, Chile GMT-3
It also shows me Easter Island (GMT-5) and this if conincide with my time.
