Hi, I am writing in finding out how a time-limited live Arlo cam works. I do not want the batteries to waste during the long motion sensor. I wish to set up the time limit of motion recording, something like 10 or 15 seconds of the motion sensor. Where do I find the settings to set up the time limit for each cam?
The default time is 10 sec I believe.... you must edit the MODE to change the time slider bar and then save
Use the green search above for steps
The following are steps you can take to verify/modify your camera's recording length.
1. Click on the Mode option
2. Select your "active" rule by clicking the pencil icon to get into edit mode
3. Click the pencil beside the rule to edit the rule
4. Under the "Rules" section, click the pencil to the right of the rule
5. Under the "Then do the following" section, click the pencil beside "Record video"
6. Move the slider from 10 to 120 seconds
7. Be sure to save any changes that you want to keep
