My boss wants to put in a security camera system in a large two-story building without paying much. Can Arlo's products be used to set up a system of 30 cameras, most wireless? Exterior cameras will likely need to be wired. Is this a realistic scenario? I've installed wired systems in the past, but have no experience with wireless systems.
In theory it is possible but for a business solution I would look at going wired or a combination for areas that can't be wired.
Issues to consider would be battery life, access to cameras to change/charge batteries, signal strength etc.
@SJBusiness wrote:
Thank you all for the responses, I'm obviously a neophyte and very much appreciate the help. Is there a way to test how strong the wifi signal is in the building and how strong does the signal need to be for the cameras to operate properly?
The easiest way is to install the Ookla speedtest app on your phone, and measure the speed at various parts of the building. Turn off your phone mobile data while you do this, to make sure you are measuring the wifi speed. The cameras need between 1 and 3 megabits upload speed while streaming. You won't need 30x times that speed, since the cameras won't all trigger at once.
Arlo cameras won't connect to an unencrypted network, it needs to be protected with a wifi password. Another thing is that some corporate wifi systems require you to log into the network, and not just connect with the network name and password. Arlo cameras can't do that login, since they have no user interface. So make sure the network doesn't require that.
Okay, thank you StephenB for all the good advice. My boss thought that this would be an easier way to go, but it looks more complex than the old wired systems I had previously installed. His ease of installing a wireless system at his home was the convincing factor, unfortunately.
