I tried the factory reset of holdin the reset button down for 10 seconds, and longer but the amber light won't do anything and is constantly on. Is my base station fried? It's about 3 years old.
None of the troubleshooting listed online worked, so I opened a case with Arlo and they sent the below instructions back, which actually resolved the problem - yahoo! 🙂 I hope this works for others as well...
1. Make sure that your home router is giving internet connection down to the through ethernet cable. So please connect a PC via ethernet cable to your router then check if you can go online.
2. Log in to your arlo app. Go to settings>my devices>select the base station>remove device
3. Unplug the base station from the power outlet then unplug your router from the power outlet. Wait for 1 minute. Plug in the router first then wait until it reboots then plug in the base station wait for 3 to 5 minutes until you see green lights on the base station
3. If the green lights will appear, go to DEVICES on your app and tap Add Device then select the base station. If the base station is not there alone then select Arlo Wirefree. Follow the installation process
4. If the base station did not lit green, or the others lit green but the internet light is not green, press and hold the reset button for exactly 30 seconds. Wait for 4-6 minutes. If you can 2 green lights from left turns green then go to ADD DEVICE, select the base station then follow the installation process.
Which light is it? There are 3
What LED is amber? If the power LED, all bets are off. A reset is done by using only the reset button, which it sounds like you did.
Swap the system at the store or open a case with support using the Contact Support link at the bottom here.
