Syncing more than one camera
  • 1 Reply
  • 4135 Views
markmisselbrook
Just bought Arlo with 2 cameras, cannot seem to sync up 2nd camera, help
Open the batterydoor and pull out, then replace ...this will reset the camera
Next, make sure the base unit is online ( first and second leds from left green )
A QUICK push of the base sync button, then a sec or so later a push on the camera sync button
If it doesn't work, reset the camera, and reboot the base via the power button ( let come back online )
