Syncing camera
- 2
One of my cameras won´t sync. I´ve tried to shut the camera of and resync but no.
The camera is blinking blue slowly
I´ve also tried to restart the basestation.
The first camera I installed is working
What could be the problem?
Håkan
What firmware is installed on the base? Should be 1.7.1_4638. If so, the reset procedure is to only use the reset button until the LEDs flash amber. Remove the cameras and base from your settings and then add them back in. Does that help?
Ad7,
If what jguerdat suggested above does not help solve the issue, please contact the Arlo Support Team for further investigation. Let us know!
You press the sync button on the camera and get no slow flashing blue LED? Swap batteries to ensure they're good. If still nothing, you'll either have to swap the system at the store or contact support:
- 2
