Storm Doris will our cams stay where they are??
If usin a threaded mount yes.... if the magnetic prob , but it's always a good idea to get a short 1/4-20 bolt ( for threaded hole ) and add a short tether from it to the mount so it doesn't fall
Obviously, it depends but mine have been outdoors using only the magnetic mounts for the past 2 years.
last storm we had here in Nova Scotia had 100km winds gusting to 140 and mag mount screwed into wall held cam up. But obviously the thread mount should hold better than the mag mount.
We had some pretty bad Thunder storms here in San Anronio, My weather station reecorded 80 mph winds. My Arlo camera mounted in a tree with deck screws stayed in place.......
I would hope so 🙂
TomMac wrote:
I would hope so 🙂
4 tornados in the area.........
those Camo deck screws are amazing.....
