You might need to contact your internet service provider's technical support and ask them if they can see anything on their end. Be sure that the base is plugged into the router and if you have a different Cat 5 or 6 cable laying around, try to swap the cable.
Brian
The amber Internet LED means the base has connection to the router but not the servers. That implies that something is blocking acces. It could be a setting in the router or something done by the ISP. Do you own the router or is it the ISP's? If yours, have you made changes to some security setting that would block a new device from accessing the Internet?
There are so many things that could be causing this. Read this article to see how some people have solved it or at least it gives you some ideas for where to start.
https://community.arlo.com/t5/Arlo/internet-is-there-but-arlo-won-t-connect/td-p/1050482
and this troubleshooting guide by Arlo
https://kb.arlo.com/996/My-Arlo-base-station-is-offline-how-can-I-troubleshoot-it
Make sure that your modem software or firewall is not blocking it. Also what modem and router are you using and who is your isp.
Brian
It sounds like the ISP owns this. Maybe they need to replace it. The other choice is that it's a configuration outside of your network that they would have to work on. Take the base to someone else's house and see if you get a green Internet LED then. It would be useful to try it with someone who also has CableOne as well as someone who has a different ISP.
