Anyone know if this may be accurate, or if there could be another reason for the interference? And, is there a work around; could I tell the system to check in at a different time (when we wouldn't be using the monitor)?
Arlo Firmware updates always happen between 3 to 5 am so I don't think the Arlo firmware updates are causing this problem. Their updates are automatic and there is no way to choose the time for updates nor refuse them so that they can be done at a later time.
Try moving the Arlo hub farther away from the router.
I don't know the model of your Motorola camera, but some Motorola camera firmware updates are between 2 to 5 am.
Is this a nightly issue - meaning is it happening every night at 2:30 am?
If it is interference, there are many things that can cause that and it will take some troubleshooting to determine where the problem lies.
Brian
Now there's zero doubt this is the cause, which isn't good for us.
I'll try moving the base station, but there isn't a tremendous amount of room there.
Firmware updates do not happen every day. Only once a week or even once a month. I believe that you have some sort of interference issue. You did not answer my question about how frequently this was occurring. You can turn off the Arlo for one night or two before the time you are having the problem and see if it clears up.
Why would the Motorola stopping to work cause the baby not to get enough sleep?
Let us know what you find out.
Brian
While it is true the Netgear updates do come in the late night/early morning... TBMK the cameras do not do this everyday on a regular basis...
If there was a check for updates, it would be from the base unit first ( which is on cable , so no interference there ).
All the updates would come to the base and then get pushed out to the cameras.
You can check the fw update list here ; https://community.netgear.com/t5/Firmware-Release-Notes/bd-p/arlo-release-notes
They do not happen that often as you are experiencing
I would be looking for some other form of interference to the motorola unit
We've only had the system for 3 nights and it had happened all 3 nights in that timeframe.
Also, I realized moving the router won't make a difference because the Motorola is a stand alone system, independent from WiFi.
Thanks for weighing in.
Moving the Arlo base station further away from the router, (and possibly further away from the Motorola monitor), could solve an inteference problem. I haven't checked lately but I believe Arlo recommends at least 6 feet away.
Brian
Disconnect the Arlo from the power source and router and see if the baby monitor works again. If so, there is an interference problem and I would recomment separating them as far as possible from each other.
Brian
