Setup camera fails to sync
Having trouble syncing my cameras. After pushing the sync button on the base the light under the icon all the way to the right blinks and my sync light never comes on.
5 REPLIES 5
Did you hit the sync button on the camera?
do a QUICK push on the base sync button don't hold , then a sec or so later the cameras button
I had this same problem. What is the far right icon on the base?
I believe it's a USB indicator but it should never be lit except during initial power-on.
That was perfect, and worked great. Thanks so much!!!
