  • 5 Replies
  • 3841 Views
  • 2 Likes
  • 5 In Conversation
timmerchiz
Having trouble syncing my cameras. After pushing the sync button on the base the light under the icon all the way to the right blinks and my sync light never comes on.
5 REPLIES 5
Chillmiester
Luminary
Luminary
Did you hit the sync button on the camera?
do a QUICK push on the base sync button don't hold , then a sec or so later the cameras button
Ecc1
I had this same problem. What is the far right icon on the base?
I believe it's a USB indicator but it should never be lit except during initial power-on.
Ecc1
That was perfect, and worked great. Thanks so much!!!
