Setting motion detection video clip duration times to 60 seconds
I want to be able to set camera times separately. How can I do this?
if you mean different times for each camera, then no as the is set in the base.
If you mean different TIME SCHEDULES for each camera , yes you can. After you make a Rule ( which camera and tells what the camera does ) and then a Mode ( tells what rules are active ) you can schedule them.
You may have to make a couple of extra Modes to include or exclude the cameras you don't want ( as you can only run ONE Mode at a time )
If you describe exactly what you want to do, someone will more than likely, give you a more exact method to do what you want.
Hello Scatrowl,
You can edit the duration of how long the camera will detect motion by following the steps below:
- Log into your Arlo account
- Click/Tap on Mode
Click/Tap the Edit /Pencil Icon
Click/Tap Edit inline with the desired camera name
Click/Tap the Edit /Pencil Icon under Then do the following inline with Record Video
Drag the slider to the desired duration
You will repeat these steps for each camera that needs adjusting.
Thank you for your contribution to the Arlo Community!
Best Regards,
Christine
____
Please click
KUDOS or REPLY if you found this helpful.
When I set the recording duration to 60 seconds, there is no save button. When I go back out and back into the camera recording time settings, it reverts back to the default 10 seconds. Could you please let me know how to save the time settings?
Thanks!
(from the web client)
After you set the recording time, click on the green text that says "back" and then hit the "save" button. This works for me.
Note that the recording duration is per camera, not per mode (despite the way it appears). So if you change "camera 1" recording duration, for example, to 30 seconds, it will change the "camera 1" recording duration in all modes.
What's the maximum clip length? From your screenshot it looks like it's around 120 seconds, but can you please clarify? Thanks
slider goes to 120 sec max recording time.
