Setting Record time for Cameras
I am unable to locate the camera record length timer under MODE, I am using Schedule for alarming the system.
--note: I have figured this out after a long search... in the mode setting, select the > on the "Armed" settings, this allows you to get to cameras and adjust the record time. "Edit" the camera select > on the "Record Video" then you can adjust the record time...basically three levels in, not intuitive an a royal pain to find if you try an use other 'answers' here.
I would agree the learning curve for any new system is high but It does make sense now. I tried some other camera systems and now like the Netgear Arlo setup. It did take about two weeks to get used to my setup. I have learned a lot from reading other posts.
