Setting Record time for Cameras
  • 1 Reply
  • 1677 Views
JPI80918
I am unable to locate the  camera record length timer under MODE, I am using Schedule for alarming the system.
--note: I have figured this out after a long search... in the mode setting, select the > on the "Armed"  settings, this allows you to get to cameras and adjust the record time. "Edit" the camera select > on the "Record Video" then you can adjust the record time...basically three levels in, not intuitive an a royal pain to find if you try an use other 'answers' here.
bhusband
I would agree the learning curve for any new system is high but It does make sense now.   I tried some other camera systems and now like the Netgear Arlo setup.  It did take about two weeks to get used to my setup.  I have learned a lot from reading other posts.
