JamesC (Netgear Moderator)
Per your note of Mar 22, Engr is aware of issue. I got a case on Mar 15, day after the new release that continue to log out within an hour. I also get emails from Netgear that my case will auto close in 3 days, (3/17,3/21 and 3/26). I have to call in and advise that problem still exists. There are so many subject matters and all the replies-got to be over 1000. Users are upset. Some are going ot Facebook, others are trying to contact local TV consumer reporters to alert them of the issue. Like so many, if I could return my system, I would. Again this happened in May and July 2017- same problem but not sure if the same tech. reason.
Not sure if you work for Netgear- Have seen your replys. I also sent a note Dawn Marshall Community Manager, NETGEAR.
When will this problem be resolve. I re-installed app today-same result.
The following suggestion was made way upthread and it is the quickest way for me. When you get the dreaded orange line with session expired, go to your arlo app, press 'force stop' and it'll say you may booger it up by doing this..ignore that...it has kept me logged in for days except for one or two instances. I am waiting for a real fix but this workaround will do for now (if it keeps working)
My Session keeps expiring as well. It has run great for 8 months with no complaints, but now starting about a week ago, every time I either go into my App to ARM or DISARM the system it sais session has expitred and I need to log off then log back in to do so, or I need to do the same to watch a video or view an alert. Several times I had to completely shut off phone and restart just to be able to use the APP as it would freeze up on the sceen notifying me the session expired. It seems I am logging in 15 times per day. I reset base station, removed and reinstalled app, as well as powered off phone.. Same problem continues. Unfortunatley becoming dissatisfied real fast as there is no way to promptly view an alert of disarm / arm the system anymore.
An update for the Android Arlo mobile app is now available in the app store that addresses this issue. Please visit the app store and be sure you are up to date on the latest version of the Arlo Mobile App: Release Notes - Android App 2.4.10 - 26th March 2018
Hello James C,
Why it's just posted in such tiny post in this giant complaints forum?? For such this serious bug that damanged all users security of using the Arlo, just a post hidden in a Forum??!!
How do you expect all users can find this post in this forum after some days, and/or they can find on this forum??
I am quite supprising that Netgear solving problem is doing in this way!!
It supposed to be that Netgear should send out a noticification to ALL users those emails that registered with their Arlo to the server, highlight the issue/bug, and the solution, and ask all users to updated their APP....
Just a tiny post sinking in the deep ocean, and expecting users to find it by themselves...!? Shame on Netgear !!
Camera VMS4130 Arlo Pro. Starting about 2 weeks ago, the Arlo signs users off after 2-60 minutes. Previous to this, users would stay on indefinately. The Arlo support is unable to help and says something that I don't quite understand about static IP address and then hangs up. I have not assigned any static IPs and the device and base have been working fine since January 4, 2018.
Thoughts?
Update to the latest app just released.
Very good job on that post I do hope it works even though I've had the system for a little over 2 years Arlo did you email me instructions for a fixed but unfortunately that didn't work just got done reading your post will retry it again I'll keep my fingers crossed thanks for posting this supposed fix
Very good job on that post I do hope it works even though I've had the system for a little over 2 years, Arlo did email me instructions for a fix but unfortunately that didn't work just got done reading your post will retry it again I'll keep my fingers crossed thanks for posting this supposed fix
Version and good luck to all
still having issues even after update.
As I said please let me know
@Rubyphilipgriffwrote:
Hello everyone in the community Arlo has fix the time out issue please log on finally uninstall and reinstall 2.4.10
I updated the andriod app to 2.4.10 this afternoon while I was at the office this afternoon. after I came home, I was keeping my eye on my phone while I was entering the Geofeing zone near my house. No notification say the system is change to disarm... then I open the app, the message pop up. session timed out.........
PS: I've now rebooted the base station, deleted the app, then re-intall, login again, will see how it goes.
VMS4330
Galaxy Note 8 : main account, active for Geofencing.
iPhone 6s+ : 2nd phone, main account login, but not active for Geofencing.
iPhone 6s : guess account grented access and set for Geofencing.
FWIW, I am getting the "Session expired" message with the new app, too, but simply use the "back" button on the device and it works fine. Not sure why the message would still pop up.
Off I installed this yesterday the 26th around 11 p.m. I've had no problem with it since I did notice the banner come up briefly but it went away let's everyone keep their fingers crossed
not getting any luck at this....
I rebooted the base station, ununstall the app from my Note 8, reboot the phone, install the app from play store, login into my Arlo account. let the phone sit for two hours..... and still getting the session expired issue.
For James C.
Moto G series Android 6.0.1
Deleted Arlo cache and data, uninstalled Arlo app, turned off all cameras and base station, download Arlo App 2.4.10_20077.
Restarted the whole system again, and tested live streaming at home.
After about two hours opened the app and the dreaded ‘ YOUR SESSION HAS EXPIRED. PLEASE LOG IN.’ appeared again.
However a quick touch on the screen; this disappeared, and it has not returned.
Tested live streaming away from home and it worked correctly, tested Geofence operation and this also worked correctly.
Thanks, it would appear that I am now back to normal correct operation.
However I have turned off auto-update from Google Playstore for my apps..
I will in future manually download any new Arlo app, AFTER I have read any reviews………..
Dunno about the fingerprint login but the updated app still gives me the session expired message but a simple use of the Back button clears it.
1  -
1  -
1  -
