Mi Arlo Camero is set to the smallest amount of sensitivity but is still detecting motion virtually every 10 minutes. I have even set it on 1 and its dtill detencting motion. How do i fis this before ANOTHEr set of batteries is required. Also are you planning on recommending a brand of re-chargable batteries
Pull the batteries out to reset the camera.
Go to SETTINGS and use REMOVE DEVICE for that camera. Now bring the camera back as new ( this will reset all settings to default ) by re-syncing.
If problems continues after these steps, contact Netgear as the camera may have a problem.
Also, make sure the sensitivity setting you're using is the one in your modes and rules and that you're saving the settings as you back out. Don't use the one in Settings under Motion Test.
