  • 11 Replies
  • 5384 Views
Greaza
Mi Arlo Camero is set to the smallest amount of sensitivity but is still detecting motion virtually every 10 minutes. I have even set it on 1 and its dtill detencting motion. How do i fis this before ANOTHEr set of batteries is required. Also are you planning on recommending a brand of re-chargable batteries
11 REPLIES 11
Pull the batteries out to reset the camera.
Go to SETTINGS and use REMOVE DEVICE for that camera.  Now bring the camera back as new ( this will reset all settings to default ) by re-syncing.
If problems continues after these steps, contact Netgear as the camera may have a problem.
Also, make sure the sensitivity setting you're using is the one in your modes and rules and that you're saving the settings as you back out.  Don't use the one in Settings under Motion Test.
tomliver57
Why can I not put my cameras in the window as when the infared is on it reflects on the glass . I can see nothing. When the infared is off its to dark and again can see nothing.
I think you answered your own question.
tomliver57
Was that you have answered your own question
tomliver57
To me
tomliver57
Was that you have answered your own question to me lol
tomliver57
I have all motion of but all motion on has vanashed.
tomliver57
When I go into settings I have all motion off but all motion on has vanashed. Help
tomliver57
It appears you haven't updated firmware or app in a long time. All Motion On/Off was deprecated a year ago. I'd suggest either resetting the base, removing all devices in Settings, My Devices and the adding the base using Add Device in the Devices tab and sync you cameras or at least creating a new mode to your liking using the Mode tab. Click on your base and create a new mode with a rule for one camera. Save and then edit that same mode to add additional rules for other cameras.
