I just installed my 2 camera Arlo system and second camera will not sync. Camera is not registered under MY Device, so I cannot remove and re-sync. I need help.
Take the camera and remove the batteries.... then replace ( watch install for correctness , label just inside shows +/-.
Quickly push the sync button on BASE ( do not hold which is the most common mistake ), then after a few secs, push the button on the camera.
If the camera still fails and flashes amber, contact Support at top of page
Sorry for the late response.
After my inquiry, I was able to solve my problem with a previous note from the community.
I did re-sync the base and the camera and it worked.
The system has been working great since then.
TomMac wrote:
snowflake16 wrote:I just installed my 2 camera Arlo system and second camera will not sync. Camera is not registered under MY Device, so I cannot remove and re-sync. I need help.
Thank you
Thank you! It worked
