  • 6088 Views
  • 5 Likes
snowflake16
I just installed my 2 camera Arlo system and second camera will not sync. Camera is not registered under MY Device, so I cannot remove and re-sync. I need help.
Take the camera and remove the batteries.... then replace ( watch install for correctness , label just inside shows +/-.
Quickly push the sync button on BASE ( do not hold which is the most common mistake ), then after a few secs, push the button on the camera.
If the camera still fails and flashes amber, contact Support at top of page
snowflake16
Sorry for the late response.
After my inquiry, I was able to solve my problem with a previous note from the community.
I did re-sync the base and the camera and it worked.
The system has been working great since then.
TomMac wrote:
Thank you
AlanDean
Thank you!  It worked
