I have just setup a nightly mode/schedule as outlined in the post IFTTT with schedule but have a question about switching modes.
The normal state of my Arlo is disarmed. I use IFTTT geofencing to arm Arlo when I leave home and disarm when I get back. The new mode/schedule is from 12:00am to 7:00am.
How do I get Arlo to change back to disarmed mode at 7:00am?
Did you chose your custom mode under Geofencing > Select Mode > Select the custom mode or schedule.
Hello and thanks for the reply.
I was hoping to do this by schedule, without using geofencing.
If you just want a schedule, then you'd just set the schedule to arm at 12:00 am and disarm at 7:00am.
With Arlo geofencing, you'd then set the Home mode to schedule, and the Away mode to armed.
Not sure how this fits in with the IFTTT geofencing though.
