Rural Setup ..... (No fixed Internet)
  • 3590 Views
nikc
Hi
I am looking to try and setup monitoring of a remote area of land I own.
There is power to the site, but no DSL / cable internet.
I was wondering if it would be possible to use a 4G/3G MiFi dongle for the internet connectivity ?
Nik
Nik... you need an ethernet connection for the base unit ( base unit creates it's own wifi system for just the cameras )
If your 4g module has one it should work but there may be high usage. 10 secs of video = 1Mb and minimum thruput for upload needs to be about 1Mb/per
nikc
Thanks !
Would it be possible to only require upload on motion / direct access, to minimise traffic ?
The camera basicly sits in a sleep mode till in use...it pings the base but that's directly.
the uploading/downloading only occurs during recording/live viewing/viewing past vids. So data only goes up to the cloud and back during actual use.
