Rose Colored tint to picture. Is it fixable? Which camera would b e good replacement for outdoor?
  • 2 Replies
  • 1189 Views
D_R_M
The picture generated by the camera has a general overall rose colored tint to it.  Is it fixable?  Which Arlo camera would be a good replacement for it for outdoor use.  I am using firmware 1.4.296, hardware H-7. and it is connectd to 4893587CA9055, VMB3000 base.
n1976jmk
Virtuoso
Virtuoso
Hi D R M!
I had that exact issue last week!
I had to remove the AC power and battery and then when it booted back up the picture was back to normal again.
Please try that!
Thank you,
Two different cameras here. The OP has an original wirefree which doesn't use AC power. In this case, try opening and closing the battery door to see if the reset clears \the stuck IR filter. If not, use the Contact Support link at the bottom here for a hardware problem.
