How many cameras can I add on VMS3230 and what cameras are compatible?
  • 1 Reply
  • 1062 Views
Mandel
VMS 3230 with 2 HD cameras, how many cameras can I add to my system, and what are the compatible types of cameras I can use?
You can run a total of 5 cameras and stay on the free plan ( 7 days storage ).
While the Pro/Pro2 cameras can also run on the original base, I would recommend an upgrade to the 4000 base series...
combo kits with cameras make the base very low cost and the newer base will allow you to run a usb backup mem stick... allowing you to retain the videos if needed for as long as there is space on the mem stick ( 64 gb is a good size )
