My door bell does not activate interior chime. Where is the reset button?
On the side of the Arlo chime:
https://kb.arlo.com/000061879/How-do-I-factory-reset-my-Arlo-Chime-or-Chime-2
Do you mean your traditional chime?
It depends on the doorbell model.
If you try a reset, then first remove the doorbell from your Arlo account. Then use the reset pin, and add the doorbell back when the reset is complete.
