Reset chim
  • 2 Replies
  • 919 Views
Overgaard
My door bell does not activate interior chime. Where is the reset button?
Do you mean your traditional chime?
It depends on the doorbell model.
If you try a reset, then first remove the doorbell from your Arlo account.   Then use the reset pin, and add the doorbell back when the reset is complete.
