Replacemet batteries
  • 4 Replies
  • 3246 Views
dopeydonald
I just replaced all of the batteries in my 3 origial cameras. The system is still saying to replace the batteries. I also added a new camera with factory batteries and it is working.
I used Duracell batteries as the replacement.
Do I need to re-synch the origial cameras
Why won't the system recognize that batteries were replaced
BTW the batteries are in proper position
It should recognize new batteries. Try power cycling the base.
888
I have the same issue but I replaced all my batteries and only had trouble with one. So I took batteries that worked in one camera and put them in it. Still nothing so I tried resync it would not resync. I'm using energizes. What is my next step?
dopeydonald
I replaced all my batteries as well as they were all dead. They did last for over 9 months which was great.
I used Duracell replacements. I also added 1 new camera which came right online
The re-synch worked for me with the original 3 cameras.
Try powering dow the base then restart it; then re-synch the cameras.
Make sure the base sync button is only a brief (<1 second) press.  Longer causes issues.
