I just replaced all of the batteries in my 3 origial cameras. The system is still saying to replace the batteries. I also added a new camera with factory batteries and it is working.
I used Duracell batteries as the replacement.
Do I need to re-synch the origial cameras
Why won't the system recognize that batteries were replaced
BTW the batteries are in proper position
It should recognize new batteries. Try power cycling the base.
I replaced all my batteries as well as they were all dead. They did last for over 9 months which was great.
I used Duracell replacements. I also added 1 new camera which came right online
The re-synch worked for me with the original 3 cameras.
Try powering dow the base then restart it; then re-synch the cameras.
Make sure the base sync button is only a brief (<1 second) press. Longer causes issues.
