Replaced Arlo batteries, still shows low battery
- Email to a Friend
I have just replaced the batteries in my Arlo camera after getting a low battery email. After putting the new batteries in it only shows as having 16% battery life left on brand new batteries. Some troubleshooting i have already done is:
1) reboot base station = still shows low battery
2) re-synced camera with base station = shows 57% battery life, rebooted base station again and then it went back down to 16%
Both my base station and camera's have the newest firmware. Any ideas what might be going on ?
- Email to a Friend
I bought new batteries today (always recommended Duracell) and installed them approx 2 hours ago, battery showed 100%. I'm now showing at 94% which is alarming.
I usually get 6-7 months out of my batteries as I rarely record or stream and use the system as peace of mind at night with motion detection.
Can anyone shed any light on this as a matter of urgency please.
Many thanks
- Email to a Friend
- Email to a Friend
I have 2 cameras and i just swapped batteries in 1 of them. It s funny because the cameras have been in the same position they are now from when i got them new and never had any issues until i swapped to new batteries and it seems to me like the arlo camera doesnt know i put new batteries in it,
- Email to a Friend
- Email to a Friend
I am having the same issue with a camera that I have always used indoors. Have replaced the batters twice, and it still shows 4% no matter what I do.
- Email to a Friend
Try power cycling the base. Also, try removing it from Settings, My Devices and resync it.
- Email to a Friend
I have done all the suggestions and nothing is fixing it, the batteries show as 70% when i reset everything and then they both drop back down. One currently at 11% with new batteries.
- Email to a Friend
are the batteries the same brand as the original ones?
- Email to a Friend
The exact brand isn't as important as just using quality name brand ones. What batteries are you using?
- Email to a Friend
This worked for me! Thanks.
- Email to a Friend
So i believe i have solved my issue and it looks to be the batteries themselves. I bought the batteries from Ebay and they were "PKCELL 123A CR123A 3 Volt Lithium Battery" and since the day i started using them the cameras kept reporting a huge battery drain. So i scoured Amazon and found recommendations from people using "Streamlight 85177 CR123A Lithium Batteries" in thier Arlo Cameras.
So i bought those and put them in my cameras and so far they look good and both camera's report 95% battery life. I havent seen any huge drains yet like with the other batteries. I will keep my eye on the batteries.
- Email to a Friend
- Email to a Friend
i accidentally bought the tenergy silver coloured 3.0 volt rechargeables and lucky if i can get a full day out of them.
The correct tenergys, the 3.7 volt gold colored ones should be here tomorrow.
Any that say 3.0 volt instead of 3.7 are going to be a problem in the arlo.
I believe the highest capacity batteries for the arlo are 750mah so anything higher than that (usually offered on ebay) should be avoided
