  • 2 Replies
  • 400 Views
KachinaShadow
Virtuoso
Virtuoso
I swapped one of my Ultra cameras with one of my Pro 3's and since the Pro 3 widget had been originally added to the WEB PORTAL as a small widget and the Ultra as a large widget, I now need to delete both widgets so that I can readd them as the Ultra being a small widget and the Pro 3 being a large widget.
The only place I had created certain cameras with the small widgets was the "Dashboard" of the WEB PORTAL...the "Devices" part of the web portal all have large widgets which only needed to be rearranged after I changed the names of those two devices.
Searching the internet yields lots of information on how to delete widgets on the app, which is easy, but all I found for the WEB PORTAL was this (below), which doesn't agree with the current WEB PORTAL Dashboard...
  • Enter Edit Mode: Look for an "Edit" button, often represented by a pencil icon or similar, on the Dashboard or within the widget settings.
  • Locate the Widget: Find the widget you want to remove in the list of active widgets.
  •  Remove the Widget: Depending on the interface, you might have options like "Disable," "Remove," or an "X" icon to delete the widget.
What I don't want to have to do is have to remove and readd the devices since they both have multiple routines to activate functions in numerous other devices.
Paul
Click on the three dots at the top right, and you will see an icon to delete each widget at the top left of the tile.  This will not delete the device itself (or affect the automations).  You can also re-arrange the widget placement by dragging the tiles around with your mouse..  Select "done" at the top right when finished.
Similarly pressing the + at the top right will give you the option of adding a widget or adding a device.
KachinaShadow
Virtuoso
Virtuoso
@StephenB
Thanks...I guess, after clicking on the three dots, those jiggling camera link windows diverted my attention away from the small gray dots with the minus to delete them.
I have added and rearranged them by dragging, but have never noticed the minus there...had to be all that jiggling going on 😜
Boy, do I feel stupid 🙄
