Can you include an option in the ios app – to remember the login to avoid needing to login each time I open the app? it's very time consuming to launch (even with fingerprint id).
These days the phone locks anyway: this extra step is annoying.
When I launch the app, I want it to immediately open.
I have a zmodo camera and that app requires password about once a month - not every time - so its fast to load/launch the app.
Lisey,
This is enabled by default, when leaving the app, do not explicitly log out, just swipe the app away/minimize. Upon returning, you will automatically log in.
Lisey,
thanks James but this is not functioning correctly as you say it should. .
I never log out of the app - and just minimise it, when i return it prompts me for the login again.
Try reinstalling the app.
I did but I will try to do that again. Thanks
