Release Notes – Base Station FW 1.7.5_6178 15th June 2016
Hi,
Anyone else experience constant "device is offline" since the firmware update? My cameras worked great, but now I lose all 3 at least once a day. I need to restart the base and hope they reconnect.
Any help would be appreciated.
Sorry, don't have na answer.... actually ran that version since 5/29 and haven't seen any changes with connectivity to cameras
New Android app as of yesterday - v2.1.1. Update and see if that helps.
One strange thing that either is a flaw or a fix after the base had its firmware updated.. about my front camera battery reading, it went from 36 to 96 about a week or 2 ago, I restarted the base a few times... Now camera is showing 90% battery. These are the original oem batteries that came with camera when I bought. Have been in the camera for over 2 months now... So weird.
I have the same issue and it happened AFTER I updated the Arlo app. Arlo system works perfectly when you access it online, but the app shoes my devices as offline.
Are you using an R7k router instead of a base station? If so, I have a trouble ticket open for this. If using a base, try restarting it.
jguerdat wrote:Are you using an R7k router instead of a base station? If so, I have a trouble ticket open for this. If using a base, try restarting it.
Nope. I am using a base station. I restarted it about 4 times in the past hour and finally, everything is functioning like normal on the app. I did the same thing last night after the Arlo app update. Is 1.7.5_6178 the latest firmware? The app doesn't show a FW update since the restart (5 mins ago), but it too was that way last night, only to have the issue reappear today (devices offline on app and firmware red triangle even with 1.7.5_6178 installed).
gljohn0 wrote:Nope. I am using a base station. I restarted it about 4 times in the past hour and finally, everything is functioning like normal on the app. I did the same thing last night after the Arlo app update. Is 1.7.5_6178 the latest firmware? The app doesn't show a FW update since the restart (5 mins ago), but it too was that way last night, only to have the issue reappear today (devices offline on app and firmware red triangle even with 1.7.5_6178 installed).
You have the latest firmware installed. Not sure why the update notification would appear. I was hoping the base restart would clear it.
Received updated Arlo software (2.1.2_13737) last night and the Android app now works flawlessly.
