  • 1 Reply
  • 2525 Views
  • 1 In Conversation
EngineerBoy
I have 10+ cameras and two base stations. Three of my cameras are showing red exclamation triangles next to Device Info. There are no firmware updates showing as available.
The cameras with the red triangles will record on motion, but I can't view them live. If I try live view it says "Connecting..." for 1-2 seconds the goes back to last image view. Cameras without the red triangle record on motion and live view just fine.
I have rebooted both base stations, rebooted all cameras, and it's still the same situation.
Any advice or suggestions?
EngineerBoy
Nevermind, it was fixed with a firmware update on one of the base stations. Did that, rebooted everything again, now all is working normally.
EngineerBoy
