I keep changing the recording time to 30 seconds. Mode, recording time, slide to 30 sec, hit save.
I am doing this on 5 cameras.
Everything looks OK when I check it.
After awhile they keep resetting back to 15 seconds.
Have done this several times.
Are you doing this on the default Armed mode? If so, don't - it's there more as an example and basic functionality and I believe some/many/all changes to it are ignored.
Create your own mode and set the time in each rule you create. Note that you will need to create the mode and save it and then reedit it to add rules for more than one camera.
I am using the default armed mode. However I always have and it has recorded longer in the past.
Maybe a software change?
I will try making my own and see if that works.
