Recording stops randomly
Recording stops randomly even though the time is set to record one minute after motion is detected. This could be a good feature if it's applied correctly by stop recording video after motion is no longer detected but I have certain situations for example, where I see the FedEx truck pulling over, the driver walking towards my door and then the video stops before the package is put on my doorstep so I don't know how good my packages are handled.
It's all about position and sensitivity. What you're describing is the way it's supposed to work. You can increase the time of recording (at the cost of battery life) or change position/increase sensitivity so that continuing motion will trigger the camera again. It's a balancing act, especially if you use minimal cameras like I do. More cameras would allow you to more optimally position them but at a cost.
I agree, it's most often a case of finding (as the baseball saying goes) "the sweet spot." Then <CRACK> there's your frozen-rope line drive of a great video hit!
