Problems:
-2 hour time stamp difference
-Camera 1senses movement, begins recording, yet both cameras 1and 2 send recordings at same time.
-Cameras 2does not record with motion sensor, nor send alert, nor email.
my arlo pro 2 motion and audio video recording is not continue just 20 & 30 sec. only record can't 5 min record. what problem??? pleas give me the solution.
You can only record up to 5 minutes IF the camera continues to detect motion. If motion stops for more than ~5 seconds, the recording ends. This can be due to the subject moving outside of the are which the PIR sensor can detect, the subject stops for some period of time before moving again, etc. You may be better served using the timed recordings.
