Recording Too Long
I have set all 4 cameras to 30 seconds of recording time upon motion. Yesterday camera 4 recorded 5 minutes 32 seconds. These have been recording for 30 seconds flawlessly for months until last night's odd recording time on camera 4. How can I fix this? Thanks.
First, I do a reset of the base via the power button. See if it repeats
The steps to correct this problem have not corrected it. I still get occasional recordings much longer than the 20+/- second setting.
I haven't had this happen but I'd try 1) rebooting the base and 2) resetting the cameras by opening and closing the battery covers. If it still happens, open a trouble ticket since it may be the new firmware that is the issue.
Was there a fix or do users still find this happening?
Try power cycling the base and maybe open and close the battery door (reinsert the battery if a Pro).
Okay, thank you. I will give that try. Although it hasn't reproduced the long recording time yet.
I don't get it. Mine is set to 10secs yet I get a 20sec clip every hour or so.
What have you tried?
Hard reset, removed the batteries, and set the motion detection sensitivy low.
What mode are you using? Armed or a custom mode?
I've actually done both resets now. I'm using the armed option, but I've played around with the other settings, motion etc. Right now I'm at 72 on motion. The problem is the shadows from the trees underneath the camera, but I need that area obviously for intruders, so setting it too low is a problem. I want to catch more motion around the base of the steps as well because of lag time.
