Thank you for the consideration!!
susienbarrie,
If your Arlo cameras are going offline, this could be due to depleted batteries or poor signal strength. What is the signal strength like for your cameras? Is it the same camera going offline? If so, it could be an issue with the conditions in which the camera is place, try swapping it with a camera that behaves as expected and see if you still experience the same issue.
PLease help
I have 5 cameras. Only one is online 4 are offline. I have tried to resync and checked batteries and nothing is working
How can I get them back online?
Thank you,
Linda
Linda1951,
Is there any LED behavior on the cameras? What happens when you press and release the sync button?
What are the LEDs on the base showing? You may need to punt and start fresh by remving all devices in Settings, My Devices and then using the Add Device button on the Devices tab to add the base and sync the cameras.
What are the LEDs on the base showing? Have you power cycled the base? When attempting to sync, are you holding the base sync button down? Don't - just briefly press it.
