Hi,
I am looking for some advice before purchasing. Anyone have a suggestion as to which cameras would be best for monitoring each room, one with a baby, and a door monitor? I will have a nanny there during the day and want to make sure everything is covered. I prefer wireless, and I am not tech savvy. Help anyone? Thank you!
If I were setting wireless cameras up inside the home, I would pick the Q cams....
If you have good coverage by your wifi, these hook into it directly, always are plugged in for power and have good rez with better motion detection ( pixel change detect ).
The down side would be you need a good level of data thruput.... If running 5 , fiq at least 5-7 Mbs upload.
Good thing is also you can buy one at a time and slowly build the setup as needed.
