Cannot See Battery Status Anywhere on App, and no low battery notifications
About a week ago, I discovered there is no way to see battery level in the Android app. No idea how long ago that started. I can view it on my laptop, but not mobile. Also, a year or so ago, I quit getting low battery notifications of any sort. So I have to constantly monitor each camera's battery level. Now I can't even do that! I had one camera with dead batteries for 2 weeks before I realized it! Why is this simple task such a challenge?? I am on version 2.7.11_25630
I'm really looking forward to the answer on this topic!
I have been very frustrated that Arlo have removed the feature, where I got an email when the battery was getting "Tired".
So stupid to remove that feature.
This is a user forum. You have to wait for a reply or open a case with support:
My Android app shows battery levels with no problem. What have you tried to fix this?
Everything imaginable. Mine used to show battery status. Give it time; you will likely lose that soon as well. Guessing it ties to either and Android OS or Arlo app update.
Maybe the lost functionalities will be DLC's for 4,99 USD
