I am looking for the best rechargeable CR123 batteries that I can find, for use with my Netgear Arlo four cam system. I bought the green stripe Tenergy that claim to have 750mah power. Six batteries with a charger run about $25. I'm not happy with these batteries, because when fully charged (only takes about an hour to charge with a 500mah charger, from what I understand, it exerts as much energy as it stores, so I'm thinking that these batteries are more like 200mah) but back to the story, when fully charged, these batteries only show the camera as being half charged, with a day's use putting it into the low battery icon, and only lasting about a week.
I have since then ordered four Nitecore batteries, rated at 3.7 volts and 650mah. Now the volts are 0.5 higher than what's to be used with the camera, I'm hoping that this does not affect the camera. 650mah is probably true from the reviews and the steep price tag they are asking of around $10 per battery. I'm hoping that they are quality batteries and worth it, and I purchased a Nitecore charger to go with it. I'll be able to test them out here in a few days and get back with everyone on performance.
I just want to know, has anyone tried the rechargeable batteries that I have mentioned? Or do you have other suggestions?
Tenergy (link here: http://www.amazon.com/Kits-RCR123A-LiFePO4-Rechargeable-Batteries/dp/B001EYHO9G/ref=sr_1_1?ie=UTF8&a...
Nitecore (link here: : http://www.amazon.com/Nitecore-RCR123A-Protected-Rechargeable-Battery-Black/dp/B00D2OCQB2/ref=pd_sim...
Nitecore charger here http://www.amazon.com/Nitecore-IntelliCharger-i4-Battery-Charger/dp/B005UAI372/ref=sr_1_5?ie=UTF8&am...
Does anyone have experience with or thoughts about the EdisonBright batteries? These are now on amazon for $20 for a 4 pack, which is about 1/2 the price of Nitecores.
https://www.amazon.com/Genuine-EdisonBright-rechargeable-protected-batteries/dp/B016R53ASA/
Here are the specs from the webpage:
Specification
Battery Size: 16340 (RCR123A)
Chemistry: Li-ion
Voltage: 3.7V
Capacity: 650mAh
Charge current: 325mA (0.5C)
Maximum Charge Current: 650mA (1C)
Maximum Discharge Current: 1500mA (2C)
Diameter: 0.66" (16.8mm)
Height: 1.32" (33.7mm)
Weight: 0.56 oz (16g)
Features:
500 recharge cycles
Triple over-heat protection
Over-discharge protection
High capacity at low temperature (-10°C)
Higher capacity and lower weight than other rechargeable batteries
Higher energy density
Free from leakage of Liquid Electrolyte
From the price history, this looks like a great deal for these: http://camelcamelcamel.com/Genuine-EdisonBright-rechargeable-protected-batteries/product/B016R53ASA
Just check the overall length... some cells are to long as allowed by makers variances.
So mic a set of OEMs and compare.
Ok please tell me exactly what to buy - I thought we could not use rechargeable batteries - I read this earlier when I first brought my cameras -- so if I buy Nitecore - what exactly am I buying and where am I buying them from - it is CR 123? it comes with rechargeable battery unit -- how much? I am ready to buy batteries now and rechargeable unit?
Vallorie
I posted the strengths left on batteries -- over 60% only the basement is gone completely - so do I need to change all batteries
Vallorie
I have no idea what OEMs mean
One page two - I have no idea how to get back to page 2
Vallorie
OEM means original equipment manufacturer.
You said OH COME ON - I wrote that because in the Manual IT SAYS CHANGE ALL BATTERIES AT THE SAME TIME - that is why I asked ==
Vallorie
I know how to use the search engine - I only asked a question -- if you have a problem with me asking DON'T RESPOND - also you need to know not everyone is computer savvy - some folks can be older on this sight and just don't know -- so be polite and answer the questions or just don't respond
Vallorie
I am going to this site - Light junction.com and order eagletec Rcr123a batteries along with nitecore I4 charger. Thank you.
Vallorie
went to LightJunction and saw this one which appears to have longer life and cheaper though out of stock - any reason why you did not get this brand
Olight ORB-186P34 3400mAh 18650 Specification:
- Olight 18650 3.7V Protected Li-ion rechargeable batteries.
- Maximum Charge: 3600mAh
- Maximum Discharge: 4200mAh
- Charge Current: 1700mA
- Charging Cycle: 500 charges
- Voltage: 3.6V
- Chemistry: Li-ion
- Weight: 49 gram
- Dimension: 18.6 mm x 69.5 mm
Vallorie
wow that is a great price re rechargeable on Amazon - I am gonna goggle reviews
Vallorie
Vallorie, I had good success with Olights, I ordered then from BatteryJunction. Prices are very reasonable there. The Charger, NiteCore D4, I got from Amazon. It's been a good combination.
I just ordered the Edison Bright batteries and recharger -- this is a great deal and the has good reviews - get it while it is HOT!!
Vallorie
Read the specs on the 18650 - they're more the size of a AA in length. No way they'll fit in Arlo. You need 16340.
I beleive they are 18mm X 65mm (18650) as opposed to 16mm X 34mm (16340) I think Tesla use several thousand in each car .
Alg.
OK I cancelled my order on Amazon re EdisonBright - just in time
Vallorie
ok great - thank you - getting Olights at Junction Battery then
Vallorie
I just received this info from EdisonBright through Amazon -- this is what they said re batteries
n Wed, Jun 15, 2016 at 1:47 PM, EdisonBright® - Amazon Marketplace
<0yyy554t7g1k8cd@marketplace.amazon.com> wrote:
Hi, Order is cancelled. However as per our knowledge, many customers use them for Arlo cameras. Could you please let us know the source for this information just for our knowledge. Thank you.
Vallorie
Specification
Chemistry: Li-ion
Voltage: 3.7V
Capacity: 650mAh
