Hi, I hoping someone can help.
I'm looking for rechargable batteries for my Arlo cameras. I see tenergy are recommended, but these aren't available in Australia, so does anyone know of other batteries I can look for?
Others from down under will chime in... Tho Netgear only supports Tenergy 3.7v li-ion and their charger, there are a few others that have worked well. ( not sure if available there )
Your looking for a major manf of KNOWN brand in 3.7 Li-ion in the 123/16340 size.
Also, you looking for a cell NOT over 800mahr ( not possible to do ) and one with protection for over charge - over drain.
Nitecore, Olight come to mind.
--** Keep in mid that theses are non supported by Netgear and if something goes wrong, your on you own
Here's a very ;long thred, start from the end as the intro info is outdated
DON"T use cheap china cells , they are overrated and can cause a possible fire issue due to lack of protection
